Whenever I turn my wheel the idle bounces around. Doesn't seem normal. Also, I have Megan coilovers and the front driverside of the car makes a rubbing sound at low speeds that goes away once I really start moving. Anyone have any idea what these problems might be? Thnx in advance.
Quote:
I think it's normal for some fluctuation because you are putting load on the system. If it is really erratic it could be the engine having difficulty compensating for the increased load. Maybe check the idle air control valve is clean.Originally Posted by run4free88
Not sure about your second issue, have you checked for signs of rubbing after removing the wheels?
