Temparture gauge went down (Evo 9)
Old Feb 7, 2015 | 08:37 PM
Evo9CTBeli's Avatar
Warmed the car up like always the temparture was halfway after getting on the highway the temparture went down climbed back up a little then down again after a couple minutes just sitting and idling the temparture went back up to normal. Any suggestions ?
Old Feb 8, 2015 | 05:40 AM
BkzProblem's Avatar
What is the temperature outside where you are located?
Old Feb 8, 2015 | 06:54 AM
bbong's Avatar
Yes, you had ice in your cooling system that clogged up the flow, temp went up, once it melted, temp went back down. Make sure you have a proper mixture of coolant in your system otherwise larger damage may occur.
Old Feb 8, 2015 | 05:57 PM
BigT's Avatar
Yes, definitely check your coolant mixture, but also replace your thermostat.
Old Feb 17, 2015 | 04:35 PM
Fast_Freddie's Avatar
Veteran: Navy
Also clean the contacts for the sensor, this happened to mine a while back and I just took some sandpaper to the sensor contact and haven't had the issue again.
monies41
Oct 3, 2006 11:50 AM
ososlow
19
Jun 30, 2002 09:49 AM
