Evo Upgrades For Beginner
Old Mar 10, 2015 | 07:59 PM
mrowka's Avatar
From: Driving ten under in the passing lane, right turn signal on at all times.
To beat the point further to death: while you're learning the car, figure out what you really want from it, and what compromises it will take to get there.
Its all about compromises. Always is.
Old Mar 10, 2015 | 08:01 PM
Jonno99's Avatar
Here's mine:
Leave it stock
Learn about tuning and get your own tools
Good set of R spec tyres
Maybe a good set of disc pads
Enjoy the car as it is then plan to upgrade later
Old Mar 11, 2015 | 01:04 AM
Runker's Avatar
After maintenance issues have been taken care of, do the following in this order:
1) Replace plastic BOV with a good recirculating BOV
2) Turboback exhaust
3) Walbro 255 fuel pump
4) Lower intercooler pipe
5) Manual boost controller
6) Boost gauge
7)Tune
Old Mar 11, 2015 | 04:34 AM
MR. EVO MR's Avatar
Small battery kit will let you installer a straighter uicp = more power then one with more bends going around the bigger battery.
Do it right the first time!
GL!!
Old Mar 11, 2015 | 01:24 PM
evo8426's Avatar
GL!!
Any UICP = Addtional $ + battery unless its OEM routed. It will not give you additional power.
Old Mar 13, 2015 | 06:00 PM
mrowka's Avatar
Tires. There's a good idea. Tires.
Old Mar 14, 2015 | 06:58 PM
FJF's Avatar
FJF
Basic mod path for a VIII: MBC, TBE, IX DV, fuel pump, tune, cams optional. The tune will make or break the car. Good luck.
Old Mar 14, 2015 | 07:24 PM
defibros's Avatar
Hey Guys! Thanks for all the advice. I got a stock evo 9 as well and have done all the maintance to ensure its up to date. Basically I am about to do my first BOLT on. I am thinking of installing the APEXI power intake kit . I am confused if I need a tune just for that?
Old Mar 14, 2015 | 07:38 PM
FJF's Avatar
FJF
Why? At best, it'll make no difference.
Basic mod path for IX: MBC, TBE, tune. That's it.
Old Mar 14, 2015 | 07:45 PM
defibros's Avatar
Reason for this mod is my air filtered looks pretty worn out so I thought instead of getting a drop in filter , I can do the first bolt on mod just to keep the maintainance up to date.
If a tune is not needed, I may just replace my filter. Please advise
Old Mar 14, 2015 | 07:53 PM
FJF's Avatar
FJF
It's a mod, alright, but not a very good one. You'd be better off using the stock airbox with an appropriate filter.
Old Mar 14, 2015 | 07:54 PM
defibros's Avatar
Pardon my ignorance, why is it not a good mod?
Old Mar 14, 2015 | 07:59 PM
FJF's Avatar
FJF
Because it doesn't do anything positive for your car. It's a common newb purchase; we've seen hundreds around here. They all work out pretty much the same; either the owner upgrades the parts, mods the kit, of tosses it out, altogether. Spend your money on parts that work.
Old Mar 14, 2015 | 08:26 PM
defibros's Avatar
so do I need a tune if I choose to install it to replaced the current old worn out filter?
Old Mar 14, 2015 | 08:45 PM
FJF's Avatar
FJF
Consider what you're asking. You're willing to spend money on an intake that doesn't do anything, except make the car run worse, and are willing to spend money on a tune for it only to make some additional noise and encounter possible drivability issues. How does that even make sense?
A tune is a great idea. Wait until you get the proper parts. I know I'm not telling you want you want to hear. You seem to be looking for a comment to support your plan. It won't be coming from me.
