source for parts bolt and nut sizes
Is there any material that shows what parts have what size bolts or nuts. Like for example the starter has a 14 x 125mm for example? So when I am putting my car back together It would be easier to know that the 14x125mm in my hand goes to this whatever part uses that size?
I dont know what thread this goes under
i just did a full build, completely tor the car apart, buy 2 sharpies cause you will loose one and sandwich baggies, label them as you pull them, if there are different sizes place baggies within baggies. really helped when putting everything back together, also i kept all the baggies in a box in the front passenger seat so any one working with me pulling or installing parts knew where to look for bolts.
Well I did do some like that but i have a few that are homeless. With my other cars the factory part catalog has the part and the siE bolts or nut associated with it. So am I S.O.L?
I can't help with after the fact bolt identification but the best way I've found for complex parts is to draw the part onto a piece of cardboard, stab holes in it where the bolts go, and place the bolts in the proper places so there's no guessing. Bags are great if all the bolts are the same or are all different sizes, otherwise they are no help.
saytheb
May 31, 2012 11:27 PM
