Throttle Body Cleaning
Old Mar 18, 2015 | 04:56 PM
rm4g3d0n's Avatar
Does anyone know what kind of cleaner I can use to clean the throttle body for a 03 evo? I looked at the back of the CRC brand and it says not to use it for turbo engines. Has anyone used it before? Is it okay?
I also wanted to use the clean to scrape off gasket remains and replace it with a new one.
Old Mar 18, 2015 | 05:38 PM
superbovine's Avatar
Just use plain old brake parts cleaner. It is cheaper and works better, plus it is less oily.
Just do not spray into the intake AT ALL. Soak a rag and wipe it out. When you start spraying into the throttle is when you start breaking stuff.
Old Mar 19, 2015 | 02:26 PM
kpr's Avatar
kpr
do not clean off the black film( moly coat) where the thottle plate closes, its there to make sure the plate seals.
Old Mar 20, 2015 | 12:43 PM
rm4g3d0n's Avatar
Okay thanks!
Old Mar 21, 2015 | 12:41 PM
rm4g3d0n's Avatar
Any recommendations on metal gasket scraper vs plastic?
Old Mar 27, 2015 | 11:59 AM
pilchenstein's Avatar
Don't clean it. There is a fine material on the inside that can't be cleaned off. It seals the throttle blade. Your issues is probably the IAC.
Evil Evolution
30
Jan 11, 2013 09:22 AM
Evil Evolution
Midwest Region
Jan 4, 2013 09:05 AM
evoforlife
Jan 23, 2011 10:05 AM
Faust
11
Jan 15, 2008 07:20 PM
