Extended wheel studs... Which lug nuts?
Old May 17, 2015 | 10:32 PM
essej's Avatar
So I broke a few studs trying to loosen some lug nuts from my factory wheels and I bought some tougefactory extended wheels studs. The wheel studs will be installed to be used with factory oem ix wheels.
I am aware that the wheels require a mag-style seat for the lug nuts.
The TougeFactory extended wheel studs I have
http://www.tf-works.com/tf-extended-...8-9-x-12x1-50/
I was wondering which would be my best option for choosing lug nuts?
50mm extended mag-style lug nuts (closed ended)
24 Extended 50mm Toyota OE Stock Factory Wheels Rim Mag Lug Nuts 12x1 5 1 5 | eBay
Toyota/Lexus oem mag-style lug nuts (open ended)
http://www.ezaccessory.com/Toyota_Le.../98-0003oe.htm
Aftermarket mag-style lug nuts (open ended)
Amazon.com: 20 pcs with 4 Lock + 2 Key Set 12x1.5 MAG OEM Style Open End Lug Nuts Lexus IS250 GUNMETAL GUN METAL Color A96: Automotive
I prefer the last option but as you can see, they do not have any available. I want to go the cheapest route and it appears that the closed ended extended lug nuts are the cheapest but I do not know if it will clear the extended wheels studs. Just because the lug nuts say they are 50mm doesn't mean they may be able to tighten all the way to the end of the wheel stud. So I don't know, I need your guys' opinions! Maybe you guys can help me find something like the last option? I wish they had those available.
Spacers are not an option as they are way too expensive.
Old May 18, 2015 | 05:24 AM
asu11's Avatar
I run these: http://www.ezaccessory.com/Toyota_Le.../98-0003oe.htm
Used on my IX BBS wheels with spacers and ARP studs. No issues.
Old May 18, 2015 | 08:22 AM
heel2toe's Avatar
I have ARP extended studs all around and for bolting up my stock wheels I just took a cutoff wheel and trimmed off the "cap" to the factory lug nuts. I'm not the first person to do this nor will I be the last but I can confirm that it is a simple process and doesnt have any safety concerns assuming you dont trim it too far down. You asked for the cheapest option and that is ti...
As for closed ended vs open ended that'll depend on how deep the lug nuts are and also takes into account your actual wheel. Your best bet it something open ended.
But just curious, if you arent planning on running spacers then why did you bother getting extended studs in the first place? You can pick up replacement studs for cheap and then you wouldnt even have to worry about different lug nuts. Hell, I've got a bunch of stock studs kicking around from going to longer studs and wheel bearings. If you cover shipping I'll gladly send them to you...
Old May 18, 2015 | 12:41 PM
essej's Avatar
Youre right! Sorry i forgot to include that im planning to run lighter aftermarket wheels. Thats why i wanna go the cheap route and then run spacers with tuner style lugs for the aftermarket wheels.
ksemski
Jul 24, 2012 03:27 PM
llDemonll
May 28, 2012 03:38 PM
injentech42
For Sale - Wheels / Tires
12
Sep 15, 2009 03:27 PM
Positron
12
Dec 13, 2008 11:45 AM
4-G-rim
Feb 17, 2007 06:12 PM
