Some help please - Video attatched
Old Jul 26, 2015 | 02:13 PM
Thehighlander's Avatar
Hi All,
ABS light is on my Evo 8
I have taken a video of the flashes but cant get my head into it to find what one it is.
Hoping one of you experienced lads could help me out please
Thanks in advance
Old Jul 26, 2015 | 02:27 PM
evo8426's Avatar
Do the lights flash at all if you do not have a tactrix cable plugged in?
Old Jul 26, 2015 | 02:30 PM
No.
Thats me crossed pin 1 and 4 to get the fault code.
When driving or idling normally the ABS light is on
Old Jul 26, 2015 | 02:34 PM
to me it comes up as 23 if i go by the ABS light.
Code 23 is Right Rear wheel speed sensor.
ABS codes
11 Wheel speed sensor (FR) system (open- or short-circuit) 35B-8
12 Wheel speed sensor (FL) system (open- or short-circuit) 35B-8
13 Wheel speed sensor (RR) system (open- or short-circuit) 35B-8
14 Wheel speed sensor (RL) system (open- or short-circuit) 35B-8
15 Wheel speed sensor system (abnormal output signal) 35B-9
16 ABS-ECU power supply system (abnormal voltage drop or rise) 35B-11
21 Wheel speed sensor (FR) system 35B-8
22 Wheel speed sensor (FL) system 35B-8
23 Wheel speed sensor (RR) system 35B-8
24 Wheel speed sensor (RL) system 35B-8
32 Acceleration sensor (longitual acceleration) circuit system 35B-13
33 Stop lamp switch system (open circuit or stop lamp stays ON) 35B-15
41 Solenoid valve (FR) system 35B-15
42 Solenoid valve (FL) system 35B-15
43 Solenoid valve (RR) system 35B-15
44 Solenoid valve (RL) system 35B-15
51 Valve relay system 35B-17
53 Motor relay system 35B-19
63 ABS-ECU failure Replace ABS-ECU.
71 Acceleration sensor (lateral acceleration) system 35B-20
AYC is flashing up 25 - 25 wrong diam tyre - Car is running wider and larger wheels.
Old Jul 26, 2015 | 04:40 PM
lonniee23's Avatar
I have sort of the same problem with my ix mr. but for me only the tarmac light is on and after about a minute of driving all 3 lights (tarmac,gravel,snow) will come on steady but no abs light. If anyone could help me out too that would be great!
Old Jul 27, 2015 | 12:57 PM
Sounds like a potential AYC issue.
What to do is get a paperclip and put it in pin 1 and 4 of the OBD port under the steering wheel.
Do what i did and record the flashes when you turn the ignition on.
I only have an ABS light on when driving.
nlp187
Jul 8, 2012 10:32 PM
cpoevo
Sep 28, 2006 01:28 PM
JDM-Spec.com
Aug 11, 2004 10:06 PM
