PC680 mini battery install cable routing
Old Jun 3, 2016 | 08:56 PM
vr4gasmtt's Avatar
I couldn't find any info about routing the PC680 with the positive and negative ground cables. I figured someone would have mentioned if it needed to be modified in order to fit. My search came up with nothing. A couple of pictures I've seen have the positive cable towards the headlights and vice versa.
As I'm mocking up the the mini battery install I noticed there isn't enough length for the negative cable or the positive cable. Am I missing something here? I figured it was straight install not needing to modify anything.
Old Jun 4, 2016 | 05:09 AM
Edit
Old Jun 7, 2016 | 11:50 AM
KFC-AWD's Avatar
Why is yours not fitting? Do you have the battery flipped the opposite way? Here is mine, didnt have to do anything.
Old Jun 7, 2016 | 12:24 PM
vr4gasmtt's Avatar
Thanks for the pictures guys, most of the pictures of what I was going off had the power terminal where your guys' negative terminal is.
HKSevolutionNYC
11
Feb 11, 2016 02:16 PM
Jedi_Gill
Jun 1, 2012 10:38 PM
sphinxof2006
Jan 19, 2011 02:24 PM
ninekrevs
14
Oct 30, 2010 07:10 PM
Lowness
May 15, 2005 04:48 PM
