running very warm on evo 4
Old Sep 27, 2016 | 03:04 PM
sexydexy_evo4's Avatar
car seems to be running very warm and fans are on alot, u cant touch the radiator or engine cover due to the heat.
had one of the pipes off and the olour of the water was like a light brown colour so I ran loads of water threw system and cleaned it abit better.
its a evo 6 engine.
the temp guage in the car seems to be bouncing about aswell.
any help please.
Old Sep 27, 2016 | 04:07 PM
Bhsj13's Avatar
check coolant level first.
Old Sep 28, 2016 | 05:48 AM
Coolant level if fine mate. I have took off thermostat and it moves fine with pressure but not when i put it in a bowl of boiling hot water. So need a new thermostat. Iam currently running with out one. Should i be ok with out it? And is it worth while getting a colder running thermo?
Cheers
Old Sep 28, 2016 | 08:41 AM
You need to run a thermostate. Too many potential issues not to run the stock thermo (water cavitation, engine heat parameters etc)
dansxr2
Sep 21, 2009 05:55 PM
EriCS
10
Feb 12, 2009 08:05 PM
LarryMags
Jan 11, 2007 06:53 PM
eccgangster
Apr 5, 2006 11:23 PM
