Idle Control valve issue EVO 8
Old Nov 4, 2016 | 10:17 AM
crisdiarata's Avatar
Has anyone change the IAC Valve? i just wondering what's the different in between those 2 valves, my car came out the one has the o-ring, but STM and other sell the other style, so when i have it replace it with the STM style didn't work right.
Attached Thumbnails Idle Control valve issue  EVO 8-iac-evo-8.jpg   Idle Control valve issue  EVO 8-iac-evo.jpg
Old Nov 4, 2016 | 10:47 AM
meckert's Avatar
Search IAC--a ton of threads, none will diagnose a pic.
Old Nov 4, 2016 | 11:36 AM
llDemonll's Avatar
left one with the rubber sleeve over the actuator machanism is for an evo 8, right one with the exposed spring is for an evo 9
the o-ring pictured is not optional, it's mandatory. the IACV's i've seen all come with one, but if they dont then make sure to re-use the one from the existing IACV that's in the car
Old Nov 4, 2016 | 01:56 PM
That make sense, but STM has the same valve for evo 8 and evo 9
Old Nov 4, 2016 | 02:22 PM
SilverShadow03's Avatar
YES, if you can, pick up the evo IX IAC...it will last longer. I've replaced 2 IACs (left pic) on my evo VIII and then finally came across one for a IX and installed it...(pic on the right). It has been a few years and the IX IAC is still going strong.
Old Nov 7, 2016 | 08:27 AM
I have got the right style and my car idler when up to 2krpm
Old Nov 22, 2016 | 11:11 PM
gotblkr's Avatar
I am also needing to replace a faulty IACV on my VIII. If I order the EVO 9 style IACV (ie picture on the right) does anyone know what the part number is for the o-ring?Would like to order this as well...
Old Nov 23, 2016 | 06:22 AM
Mitsubishi / MD628313 O-RING,THROT BODY IDLE SVO
Or you can use: Mitsubishi / MD628092
Old Nov 23, 2016 | 02:09 PM
gotblkr's Avatar
^^^ Thanks man!
hyeteck
Sep 10, 2011 07:39 PM
black95tt
Apr 21, 2010 04:49 AM
Toxin
15
Mar 14, 2009 12:47 PM
850RCT9A
Mar 1, 2009 07:05 PM
elhalisf
Apr 25, 2008 04:40 PM
