Cleaning the fuel tank
So I'm sure there are better ways but this is what I did...
Drove until my gas light came on, let it idle for a bit till I figured it was running on fumes. Pulled the fuel pump, shop vac'd the remaining gasoline. Used a brush and some elbow grease and just cleaned it through the fuel pump hole. My brush was able to reach the whole tank. Rinsed it, vaccumed, put it back together, jerry canned about two litres of gas into it and took it to the gas station. Still looked mint when I replaced my Walbro with a DW.
I'm cleaning it this week. So I will wait few day and decide if it's worth doing it without removing the tank.
There should be two drain bolts on the bottom of the fuel tank, you can open them and have drain pan underneath, and use some carb/intake cleaner spray?
Never tried, but I got pair of fresh washers just in case I have to clean the tank.
When i converted over to E85, I pulled both plugs
MisUnderStood
Dec 16, 2015 08:53 AM
ryukinevo
Nov 13, 2015 12:00 AM
Evo_AK
Dec 29, 2013 09:38 AM
jessmanEVO
Mar 2, 2012 10:32 PM
