Best way to install motor/trans?
Old Jan 3, 2017 | 11:11 AM
black_beauty's Avatar
Need help on how to attack engine install. I pulled to motor/trans together from the top after removing tcase etc. Is this the best way to put it back in the car? Motor/trans mated, then wrestle tcase back in? Thanks
Old Jan 3, 2017 | 02:02 PM
Ryan4dc's Avatar
Maybe leave the t case in place and have it pushed to the side while you drop the motor and trans from the top? Can unbolt and bolt in the t case while the subframe is in place.
Old Jan 3, 2017 | 03:34 PM
barneyb's Avatar
With the fender side motor mounts fastened jack the bottom of the engine forward.
Old Jan 3, 2017 | 09:29 PM
4b11slayer's Avatar
Long block from top, tcase set in place, trans with studs removed raised from floor to top via cherry picker
rACerS
20
Apr 14, 2009 08:01 PM
jezefink
Feb 27, 2008 10:24 AM
bishiboy
Jan 19, 2005 07:34 AM
CCu5toMz_RJ
Jul 19, 2004 11:58 PM
wojo
Mar 25, 2004 01:27 PM
