Question Compression Test Help
Old Mar 12, 2017 | 06:31 PM
MrEvo9Mong's Avatar
Did my compression test today got some pretty low numbers now i know it should be 155-180 +\- 15 and consistent between all four cylinders, but im reading mix reviews on here that as long as its +\-15 of eachother its fine and if the head is cammed its normal and some says its not and so forth, so wtf am i looking for exactly? This was done on a dry test 45min after the car was shut off
C1: 100
C2: 100
C3: 92
C4: 110
(Note: i did the test twice and same result)
Now am i ****ed or am i good? Lol
Mod List: ( Dont know if any of these will affect anything but its a general idea to answer future questions )
E85 Tune
GSC S2 Cams
GSC Springs/Retainers
BR Ported OEM IM
BR Ported OEM EM
MAP Ported 65mm OEM TB
DW300 Fuel Pump
Kiggly Racing HLA Pressure Regulator
1050cc FIC Fuel Injectors
Synapse DV BOV
Muse Lower/Upper IC Piping
ETS 3.5inch FMIC
ETS Intake w/MAF Sensor
Invidia 76mm Test Pipe
MAP Dump/Down Pipe Combo
Tomei Titanium Expreme Catback Exhaust
Mishimoto Radiator & Hoses
Spoolin Up COP Kit
Denso Iridium IKH24 Spark Plugs
Hallman MBC
Stock Turbo
Stock Block
Stock Tranny
Stock Clutch
Old Mar 12, 2017 | 09:41 PM
4b11slayer's Avatar
Definatley low numbers.
How many times did the engine spin when doing the test? If you crank it longer does the max psi stay the same?
Next order of biz is to do a leak down test. See were the compression is being lost. I.e rings,valves,head gasket.
Old Mar 12, 2017 | 10:21 PM
MrEvo9Mong's Avatar
6-8 times each cylinder and wont go past the psi as stated above, should i try a wet test first before leak test?
Old Mar 12, 2017 | 10:28 PM
4b11slayer's Avatar
Wet test it. If it rises its likely a ring issue.
Is the car using oil?
Old Mar 12, 2017 | 10:53 PM
MrEvo9Mong's Avatar
By using do you mean burning? If that than no it doesnt
Old Mar 12, 2017 | 11:07 PM
4b11slayer's Avatar
Yes burning. Hmm usually bad rings burn oil.
Do a leak down, report back.
Note: you gotta do leak down test on tdc compression stroke.
Old Mar 12, 2017 | 11:17 PM
MrEvo9Mong's Avatar
Ok what percentage should i be looking for? 10%? 15%?
Old Mar 12, 2017 | 11:21 PM
4b11slayer's Avatar
%5.
The percentage shouldnt matter at this point, you just need to find out where its leaking to repair it.
Old Mar 13, 2017 | 12:50 AM
RightSaid fred's Avatar
Photos of spark plugs?
Old Mar 15, 2017 | 08:20 AM
Bacek88's Avatar
the only thing I would also suggest is trying a different tester. With the numbers being more or less even across the board I think your tester may not be reading accurately
Old Mar 15, 2017 | 09:02 AM
MrEvo9Mong's Avatar
Yea same result but my tester is brand new from the store and the sencond tester is from oreilly which was really ****ty cause of the leakage at the connection, so gonna have it leak down test it today. Will post results.
Old Mar 15, 2017 | 09:03 AM
MrEvo9Mong's Avatar
Dont have any at the moment but they look pretty good but ill take some for you when i perform the leak down test
Old Mar 16, 2017 | 11:54 AM
MrEvo9Mong's Avatar
Results!
So after a day of testing, come to find out that my rings are bad. Wet test demosntrated a increase ammount of 15-20 psi per cyclinder with cylinder 4 at highest.
Wet Test:
C1: 132
C2: 138
C3: 140
C4: 148
Leak-Down Test:
C1 - 75%
C2 - 15%
C3 - 5%
C4 - 5%
Old Mar 16, 2017 | 08:32 PM
4b11slayer's Avatar
Originally Posted by MrEvo9Mong
Results!
Wet Test:
C1: 132
C2: 138
C3: 140
C4: 148
Leak-Down Test:
C1 - 75%
C2 - 15%
C3 - 5%
C4 - 5%
Your sure you were at true tdc on compression during the leak down test?
Crank pulley tdc is only good for cylinder 1 then the rest need to be set to tdc with a screwdriver in cylinder till tdc and has to be compression? Was the leak down coming from dipstick or oil cap?
Old Mar 16, 2017 | 09:21 PM
MrEvo9Mong's Avatar
We did them all with a long extension to set tdc on all four cylinders, and if you meant by air escaping we didnt bother to listen for air and went straight to the wet test cause the leak down test was different from the dry test (i tried a new comp tester and got C1: 110 C2: 110 C3: 120 C4: 115) so thats when we went for the wet test
