Not even a shop knows what's wrong with my car 😔😔😔😔
Exhaust can? Cam? Polished? A little damaged? Well there ya go. There is no such thing as a camshaft a little damaged. Base circle of the cam must be round to within .0005" inch. If there was a nick or a ding in the cam that was polished out, that's more than likely your issue.
I'm surprised you are getting much sealing if the engine is that new. The rings probably aren't even worn in, I'd think.
kikiturbo could be right: Once the engine is running and the lifters fill, the valves could be stuck open. If you have new valves and they didn't grind them to fit, that could be the problem.
That's one of many possibilities.. and one of the hardest to check.
Understand the concept of hydraulic lifters, oil pressure fills the lifter and holds it against the camshaft. When the lobe comes around and pushes it open the oil doesn't compress. When the valve is closed the lifter is in constant contact with the lobe, but this part of the cam is round so the valve doesn't open. If there is a low spot even .0005" your done. Once the lifter gets past the low spot on the cam it will hold the valve open ever so slightly. It don't take much since the rocker ratio exaggerates the bad spot in the cam.
"Quote
Bleeding the lifters fixes the issue, so that's why I don't think your valve stem clearance is the issue. Besides as soon as the car cooled down your valves would seal back up."
I have done compression test when my car was cold like a day latter and i still got the same result. doesn't the lifters bleed themselves when there is no oil pressure in them? few knows shops that i have called are all pointing towards the valve stem height. i will measure the valve stem height before i take the head off so if that is not the issue i don't have to take anything apart.
If it was the stem height bleeding the lifter would not have fixed the issue. Plunger would be bottomed out in lifter if it was a stem height issue. To make absolutely sure it's not a sticking valve you could make sure the cylinder has no compression then check between the camshaft and the rocker rollers with a .002 feeler gage ( some sets go down to .0015) if you can fit a feeler between any of the rollers at TDC on the compression stroke for that cylinder, it's the valve sticking open. Look for loose lifters when the rockers aren't up on the lobes.
Note: you should run the engine for a couple of seconds right before you do this
Yes everything is new in the head besides the lifters and all are GSC products and jiggly HLA.
Well if that is the case it certainly could be the valve stem clearance is to tight causing the valve or valves to stick slightly open. This happens when the engine heats up, the valve stem expands causing it to stick in the guide. Usually when the engine cools the valve closes, but not always. Do the above checks.
So an update I finally figured out what the problem was. What happened when I blew my motor my exhaust cam was damaged so I send it to a cam shop to get it fixed apparently they didn’t get it right. I swapped it out for a used cosworth I had and whala it worked like a charm so I oedered a gsc exhaust cam and got compression on all cylinders. Just wanted to let you guys know about my find. Thanks everyone for the helpful tips
