Fender Flares
Old May 11, 2017 | 03:03 PM
smoothevo's Avatar
Fender Flares
Gus are there any better options than this https://www.evolutionm.net/forums/ev...l#post11483554. I'm only looking to extend the rear quarters out maybe 1".
Old May 12, 2017 | 06:12 AM
subiekilla's Avatar
Rolling your fenders is probably your best option. Make sure you do it right tho.
Old May 12, 2017 | 06:48 AM
smoothevo's Avatar
Took it to a reputable shop and they cracked both along the lip so now I'm looking at other options.
Old May 12, 2017 | 08:32 AM
nemsin's Avatar
Old May 12, 2017 | 10:10 AM
smoothevo's Avatar
Originally Posted by nemsin
Love it but overkill for me. I'm only running 18 x 9.5 +15 so I need a little more room in the rear so I don't have to run -1.5 camber.
Old May 12, 2017 | 05:03 PM
Grimgrak's Avatar
What kinda front fenders are those?
Old May 12, 2017 | 06:00 PM
nemsin's Avatar
Pretty sure its Varis http://www.bulletproofautomotive.com...r-kit-4-pieces
Old May 13, 2017 | 06:26 AM
I think we have commented on your wheel set-up prior. That +15 cant be fitted, in the rear, properly on the stock body. BTW, -1.5 is a perfectly OK rear camber
Seems like you have reached a point on this spec: Cut the rear fenders & install some form of overfender or sell this +15 for a higher offset wheel
Old May 13, 2017 | 06:46 AM
smoothevo's Avatar
Doesn't rub to bad in the rear with stock camber right now and my car only has about 1 finger gap of clearance. With more camber I think it would fit fine. Hell if I raise the car up some I prob wouldn't even need to run any camber over stock. I will say the roads are very nice where I live so that makes a big difference. I'm not racing or hitting huge bumps and that's where this setup won't work.
I'm looking at flares for a few reasons, avoid running any negative camber, I like the look and the shop did a crappy job on my roll so I'm worried the paint will continue to crack. By the way this setup looks so damn good even the wife likes the car now.
Old May 13, 2017 | 07:10 AM
nemsin's Avatar
You should find a body shop with experience shaving/rolling fenders. Like find out where your local stance/hellaflush crowd goes. You can do less extreme fender pulls
Old May 16, 2017 | 01:11 PM
smoothevo's Avatar
-1.5 camber all around with 18x9.5 +15 245 35 and I'm good to go now. Didn't have to do anything aggressive to make them fit just normal roll on the rear quarter. Suspension had a good workout on bad roads and no rubbing.
Sir Lancelot
Dec 10, 2004 10:50 AM
mdiez1
Nov 30, 2004 06:02 PM
blacklancer03
Jul 9, 2004 06:47 PM
EcrsEvo
Feb 11, 2004 05:32 PM
ASTROEVO
Jan 19, 2004 06:20 PM
