Cams or Bigger Intercooler?
Old Jul 18, 2017 | 11:51 AM
reboundicon's Avatar
I didn't see an intake on your list, so that would be one of the first things I would get (AEM). Also for affordability and what you're looking for in terms of power, you can go for an Evo 9 turbo, downpipe, lower IC piping and HFC/TP will get you there. The stock intercooler is already pretty good, and cams won't give you huge gains unless you are upgrading everything else IMO.
Old Jul 29, 2017 | 12:52 AM
TariqEvo's Avatar
I do have a K&N intake, forgot to mention that..
im thinking an fp turbo,
bigger intercooler,
bigger cams
and bigger injectors..
do u think that's sufficient enough?
Old Jul 30, 2017 | 11:51 PM
mines5's Avatar
Tariq Bhai.
Get GSC S2s + ETS 3.5 Inch IC.
FIC 1100 High Z -
Fp RED MHI housing.
SD kit.
and enjoy the beauty of kenya.
Old Jul 31, 2017 | 07:02 AM
2winscroll's Avatar
No need to upgrade to lager cams for 450 hp. Turbo and intercooler are the restriction.
Old Jul 31, 2017 | 12:56 PM
maxroach's Avatar
Originally Posted by TariqEvo
I have an 03 evo 8 GSR
I wanna get to around 400-450hp
Cant decide whether to go with a bigger intercooler or big cams
with cams I'm thinking GSC S2 and will change springs and the head studs.
Currently running stock cams and the small stock evo 8 intercooler
Current mods
Walbro 255LPH Fuel pump
ACT Streetlite flywheel
Perrin 3" full exhaust system
Gates Perfomance timing and shaft belt
Hallman Pro RX MBC
and I have a TurboXS full piping kit on the way
got a pretty good deal
any advice would be greatly appreciated, even if its something other than IC or cams
400-450 is Impossible! even with Evo 9 Turbo, s2 cams and big intercooler and pump 93 gas.
I suggest,
Cams and big turbo! FP Red or black.
Old Jul 31, 2017 | 05:01 PM
Jonno99's Avatar
Originally Posted by mines5
Tariq Bhai.
FIC 1100 High Z -
Fp RED MHI housing.
SD kit.
aim for something like this and youll be around 400 and call it quits on pump
Old Aug 1, 2017 | 04:21 AM
TariqEvo's Avatar
Tariq Bhai.
FIC 1100 High Z -
Fp RED MHI housing.
SD kit.
looks like this is what i'll do, though i have zero knowledge on speed density
Old Aug 1, 2017 | 04:23 AM
TariqEvo's Avatar
havent people done 600hp+ on pump gas?
Old Aug 1, 2017 | 04:33 AM
mines5's Avatar
Even with a 6466 you cant make 600 whp on pump gas. Atleast that is my experience.
Old Aug 14, 2017 | 06:32 PM
GN Exia117's Avatar
my stock ix turbo i got 420 whp out of it at English racing. on e85 on stock ix cams. but 8 definitely gsc2 would help out.
Old Aug 22, 2017 | 07:51 AM
TariqEvo's Avatar
Oww wow thats quite impressive..
Old Aug 28, 2017 | 02:13 AM
Johnboy1065's Avatar
I would do the cams first.
Old Aug 29, 2017 | 12:55 PM
2winscroll's Avatar
Cams will literally get you nothing with a stock turbo. Any results that show you differently are doctored. Besides they will just slow you spool.
Old Aug 29, 2017 | 08:45 PM
Boost Demon's Avatar
Veteran: Air Force
For the sake of this dicussion, I'd go with a nice Garrett core FMIC as was already mentioned, this will keep things reliably cooler run after run especially if you go with a larger turbo. A good camshaft upgrade will show a nice gain on your 8 and has been proven to over and over on stock turbo setups.
Old Aug 29, 2017 | 09:39 PM
2winscroll's Avatar
On 93 octane maybe some slight gains. E85 you get almost nothing. It just shifts the torque curve higher in the rpm range. But go ahead and try cams, hopefully you can fool yourself into thinking its got a lot more power after you speed all that $$$$.
