What is this for??
Old May 21, 2018 | 06:23 AM
RRevoixMR's Avatar
What is this for??
I dropped a wrench around the battery area and underneath the battery tray I accidently moved this switch/clutch type of thingy. Anyone know what this is used for? You can move it left and right and it clicks. It looks like it connects with the clutch cable or something.
Old May 21, 2018 | 06:25 AM
Weighted gear selcector lever
Its what actuates your gear changes
Old May 21, 2018 | 06:39 AM
RRevoixMR's Avatar
Thanks! So what happens if I either move it left or right and just leave it? Cause I am not sure if I left it at the same spot after I accidently moved it.
Old May 21, 2018 | 06:40 AM
Do you still have the shift cables attached? If so, that is no problem. It wont affect anyting
Old May 21, 2018 | 06:44 AM
RRevoixMR's Avatar
Thumbs up
Dont think it matters. Once you reconnect the shift linkage you should be able to select your gears or neutral as needed
Ahh okay. Good to know I didn't mess anything up then. Thanks a lot!
