Leaking
Leaking
So my 06 evo 9 is leaking a red fluid im pretty sure it is coming from the acd pump. If it is leaking from the acd pump should I not be driving it? Where do I fill it up after I fix the leak? Thank you in advance
No reason you can't keep driving it. Once it gets low enough you will get the acd pump error where all 3 lights (tarmac, gravel, snow) are lit up at the same time but it wont hurt the car driving, it will just act as an open diff. The acd fill reservoir will be right behind the driver's side headlight with a white cap. You may want to bleed the acd after fixing the leak.
What
