Evo IX P0335
Old Jul 17, 2019 | 02:20 AM
603Guy's Avatar
Evo IX P0335
Hey everyone, recently picked up my first Evo IX MR July 1st and unforunately i'm already having issues. The car has a full build on it from TS Comp tuned & tuned by RRT in CT with only 48,000 miles (8k on the build). I'll definitely be positing more about the car once i get this resolved. The issue at hand is when i go to start it, it doesnt and after a few attempts it will throw a "P0335 Crank sensor code on Circuit A". It started acting up last tuesday (the 9th) but ended up firing up at the end of the day. Ran completly fine from then until yesterday. Replaced the battery just incase, no change. Picked up a new starter (not installed yet) in case as well as a new Crank sensor from MAP (sensor will be here thursday) but in the mean time i was wondering if there's any tricks to get it going again. Could the P0335 be a byproduct of another isse? I checked all the major grounds and nothing is loose or severed. Has given me zero driving issues when the car does run. Also, P0335 is the only code populating, no camshaft (P0340) codes. Any help i can get would phenomenal, thank you in advance.
Old Jul 17, 2019 | 05:48 PM
barneyb's Avatar
Probably the sensor.
Old Jul 18, 2019 | 05:38 AM
603Guy's Avatar
Wasn't the sensor. The stud on the starter that recieves power from the car battery broke inside the starter itself so it was loose. The inablility to start and not send proper voltage the crank sensor prompted the P0335 code. All is good now.
