A/F gauge question
Originally posted by Z1 Performance
As I said you CAN moniter 02 sensor voltage on a SAFC2 - it can only do it narrowband signal though.
There is an alternate input wire, Its not a true O2 gauge, but the sensor input wire for the other sensor that is unused on the S-AFC configured for MAF (Karmann)
The problem is there is no direct "Gauge" for it, but there's a mode called Sensor check, whic displays the Sensor voltages for TPS, MAF, and VPS (Vane Pressure Sensor) so if its hooked up, it will register a voltage on that screen...
Its not a true built in feature, but something we had discovered early on that can be done.
Again, like I said before, don't rely on a Narrowband sensor (factory O2 sensor) for being able to adequately tune safety, but it will be able to tell you when the settings are horribly off and lean enough to be dangerous.
iLLevo_
16
Feb 19, 2017 09:30 AM
cleanIX
Feb 1, 2010 06:39 PM
Gruppe-S
Evo 'For Sale' Exterior Styling
21
Jan 9, 2007 06:57 PM
Obsoleteasian
Jul 27, 2004 02:19 PM
RallySport Direct
May 18, 2004 02:54 PM
