Axle to to t case seal
Old May 15, 2020 | 04:49 PM
HeartFix's Avatar
is the seal interchange for both driver and passenger side? i bought the driver side by accident when i shouldve bought the passenger.
Old May 19, 2020 | 06:32 AM
driven168's Avatar
Yes it is, you will be fine. You will likely have a harder time installing it into the rear diff, I know I did. I ripped one and ended up buying the tool to seat it in properly.
Old May 19, 2020 | 06:43 AM
Boostindsm22's Avatar
harbor freight has a cheap seal installer that might help when you go to install it.
Old May 19, 2020 | 06:48 AM
driven168's Avatar
^ +1. Thankfully, it was no where as ridiculous as replacing the TB shaft seals hahaha.
Old May 21, 2020 | 03:24 AM
HeartFix's Avatar
do i have to remove the inner shaft to install it? or can i leave it in?
Old May 21, 2020 | 06:18 AM
removing it would make it easier
Old May 22, 2020 | 05:53 AM
driven168's Avatar
Oops I misread the thread title, I thought it said rear diff. For the t/c seal there are several threads on here for that, good luck!
ChrisWantsBoost
Feb 14, 2016 09:54 PM
Dann
Nov 14, 2013 04:00 PM
keevo54
Jan 16, 2012 07:17 AM
Darkn3s
Feb 15, 2011 03:03 PM
bboy_RES
May 12, 2008 09:07 AM
