ETS Test pipe O2 bung location problem
Old May 3, 2021 | 09:23 AM
Kirye's Avatar
Unhappy ETS Test pipe O2 bung location problem
Hey all, I recently installed a new ETS test pipe (straight through) and the location of the O2 bung is not in a good spot. I have an invidia downpipe, however it maintains the stock location of the flange. The location of where the O2 bung was welded puts the sensor right up against the driveshaft making contact. Even if I rotate the pipe end for end, same result. I obviously can't rotate the pipe 180 as the bung would be facing the ground. I will update later today with pictures, I've contact ETS and am waiting for a response to see if this is normal. Any thoughts?
Dr.Chris
Mar 18, 2016 03:29 PM
ThaoDao
Jul 7, 2014 02:32 PM
sik_z33
Jun 1, 2014 10:36 PM
bobby0283
May 21, 2011 11:32 AM
