MAP sensor
Old Dec 28, 2021 | 06:44 AM
pistons4550's Avatar
MAP sensor
My map sensor went bad, is there another replacement option other than OEM that WONT require a retune?
Old Dec 28, 2021 | 10:23 AM
CurseDSM's Avatar
Only thing that would come close would be a Omni but you would have to rescale being I don't think they come in a 3 bar.
Old Jan 3, 2022 | 09:57 AM
Evo9isLife's Avatar
5 Year Member
Any map sensor other than oem will require scaling in ecu. Go with oem evo X map if you are upgrading from stock, omni map are known to fail frequently.
Old Jan 3, 2022 | 01:24 PM
Kevin.'s Avatar
+1
I've read good things about using the X sensor
Old Jan 4, 2022 | 07:12 AM
Thanks guys. I will check out the Evo X sensor
Old Jan 4, 2022 | 07:35 AM
Evo9isLife's Avatar
5 Year Member
It will still require scaling in ecu btw, its not plug and play.
Old Mar 9, 2022 | 07:15 PM
Has anyone purchased from Nengun before. They sell the OEM evo x Map sensor 50 bucks cheaper than anything else I’m seeing.
Old Mar 9, 2022 | 07:50 PM
kyoo's Avatar
i've purchased from nengun. it comes from japan though, is it really that much cheaper than map or stm including shipping?
Old Mar 10, 2022 | 03:32 AM
160 with shipping on nengun vs 230 on MAP and STM for 1865A052
Old Mar 10, 2022 | 05:44 AM
kyoo's Avatar
gotcha - yea i personally have had no problems ordering from them, typically aftermarket parts.
Old Mar 10, 2022 | 11:17 AM
Kevin.'s Avatar
What are you doing for a tune if you go X sensor or aftermarket?
https://www.ebay.com/itm/32456022141...3ABFBM6peT1O5f
If you need an OE 8 MAP sensor I think I have one
Old Mar 10, 2022 | 11:56 AM
my tuner said he just has to do some rescaling. Thanks for the link I’ll check it out!
Old Apr 22, 2022 | 02:53 PM
Switched to the Evo X sensor. Had my tuner adjust the tune. I’m getting p0069 now when I start the car up though, runs well. Anybody else experienced this? It says barometric pressure correlation and from what I been reading some people have disabled the test? Is there no other way
hyeteck
Jul 16, 2011 03:56 PM
vroomevo
Jan 12, 2007 09:07 AM
