The Hood won't close with hood shocks
Old Jul 25, 2023 | 07:06 PM
rightaway's Avatar
I bought this car and it had these shocks. Hopefully, you can see in the pictures that it won't close all the way. I see people running them at car shows and have no s no issues. What am I doing wrong?
Old Jul 25, 2023 | 07:13 PM
Chrispy0530's Avatar
Don't see any pictures. Might want to try and re-upload them.
Old Jul 26, 2023 | 08:54 AM
rightaway's Avatar
Old Jul 26, 2023 | 08:55 AM
rightaway's Avatar
Sorry I thought I posted them. I'll try again
Old Jul 26, 2023 | 09:23 AM
RallySport9's Avatar
On the top portion of the dampers, you have them reversed. That little ball joint should be facing outside. Actually I think they're completely reversed. The right one should be on the left and the left on the right. I even see an "R" on the damper you put on the driver side which should be left.
Old Jul 26, 2023 | 11:00 AM
rightaway's Avatar
Thanks I didn't see that. I switched them and it still doesn't close. I feel like the tabs are to be.
Old Jul 26, 2023 | 11:16 AM
Terror Rising's Avatar
Does it close properly with the gas springs off the car?
Old Jul 27, 2023 | 03:27 PM
rightaway's Avatar
Never thought of taking them off so u did and it still sits high. How would I got about getting the hood lined up? Is the good latch adjustable?
Old Jul 27, 2023 | 03:30 PM
Check your hood bumpers? Although I don't see why that would change if it wasn't touched, same goes for the latch. Weird.
Old Jul 28, 2023 | 04:21 AM
There are two rubber stoppers on the radiator support that can be threaded in and out to adjust how high up they support the hood. If you thread them in and the hood doesn't go lower see if you can lower the latch as mentioned above.
Old Jul 29, 2023 | 09:21 AM
Kevin.'s Avatar
https://evoscan.com/wp-content/uploa...00000900-8.pdf
Old Aug 5, 2023 | 08:25 PM
rightaway's Avatar
It's saying to loosen up the hood hinge and adjust it from there. How will that help with the issues I'm having? How do I slide the hood downward? If so wouldn't the hood overhang?
Noize
Mar 22, 2012 02:03 AM
brendend
Jun 27, 2008 05:49 PM
sickblklancer
Jun 28, 2006 09:35 PM
beanutoo
Dec 8, 2004 01:56 PM
