Passenger window only working from passenger switch
Old Dec 29, 2025 | 06:27 PM
bevo7's Avatar
My passenger window will only work from the passenger switch and not my main driver switch, I tried resetting the window and still not working on the main. Not sure if it could be a failed passenger switch on my main switch or what the issue could be seeing if anyone has had a similar issue.
thanks
Old Dec 30, 2025 | 07:10 AM
schuhie's Avatar
That's an interesting one. I would probably start poking around with a meter initially by checking that the driver switch is working at all.
Here is a link to the evoscan manuals. These should have wiring diagrams in it to help narrow down the issue if it isn't a simple switch issue.
https://evoscan.com/tech-articles/#e...iring-diagrams
Old Dec 30, 2025 | 07:34 AM
ViciousLSD's Avatar
I think I read somewhere in here that the plug inside the door can come loose. maybe worth a look
Old Dec 30, 2025 | 09:25 AM
bevo7's Avatar
I’m gonna start testing with a multimeter and see what happens when I press the switches, I might also add that it’s a evo 7 and I removed the rear left window motor and after looking at some wire diagrams the wire harness could be run in series and possibly because I removed the rear motor the main switch isn’t connecting to the passenger window and possibly why the switch works by itself. Not sure at all could just be talking crap but process of elimination
Old Dec 31, 2025 | 05:10 AM
Ozwald's Avatar
Veteran: Air Force
Info you need
Here are the manuals for testing and the diagram.
3100-00E is the "How To"
400-90 is the Diagrams for the car. Open it up and CTRL+F "door" the switch is the 3 or 4 hit
File Type: pdf
File Type: pdf
EvoGSR8
Mar 10, 2014 02:19 PM
anyoneelse
Aug 10, 2007 12:55 PM
