Which Blow-off Valve?
I want what blow off vavle people have been using. I tried the Turbo XS and had bad luck with it had to return it the dealer said something about not being able to handle the boost. I want to hear what other evo drivers have been runnig and how it worked for them
i tried a forge, then went back to stock, i recommend stock unless your running high boost...others will say that it leaks, but i have yet to see hard evidence that it leaks, on here someone tested it, and found it not to leak so....VTA will cause you problems on the MAF system, you'll have to get standalone for it.
If anything i would recommend the Turbosmart Dualport (60/40) it blows off 60, and recircs 40% to keep the ecu happy.. plus it keeps your ears happy too
