bypass oil filter
Old May 28, 2004 | 07:19 AM
jamieritchie's Avatar
bypass oil filter
has anyone installed a byspass oil filter on their evo?? if so, where did you return the oil to the block?? i've got one on my grand national and i had to return through the oil fill cap. i've got pictures but how do you make them small enough to post?
Old May 28, 2004 | 01:32 PM
nothere's Avatar
can't you use a fitting on the oil filter mount to pick up and return? I believe canton mecca and others have that fitting.
Old May 28, 2004 | 05:23 PM
what is this canton mecca? i'm still using the stck style filter only bigger (wix 51334) and i am going to add an additional filter (bypass).
Old May 28, 2004 | 05:35 PM
nothere's Avatar
canton is a aftermarket racing filter maker, they have a remote system that mounts a fitting to the filter mount so you can run hoses to a remote filter, filters, whatever you want.
in a remote location you would have room for a bigger filter, as you prolly know there isn't much room under a lowered car.
http://www.cmfilters.com/remote.cfm
(sorry, didn't understand the original post)
pss, I think the aimsoil people have the same gear and they sell a bypass filter don't they?
