View Poll Results: Which gauge pod do you prefer?
On dashboard
17
13.28%
On steering column
20
15.63%
On pillar
59
46.09%
Inside DIN
25
19.53%
Instrument cluster
5.47%
Voters: 128. You may not vote on this poll
What are your opinions about gauge pods?
I'm trying to get a gauge (no pun intended) of which gauge pod I should get I'm really leaning toward a dashboard type as it seems to be the cheapest out there, but would require a lot of cutting. Which do you guys prefer?
I just got the 42 Draft Design Din mount and 3 VDO guages, I am very happy with it.
42 Draft Designs now has a set up just for Evo's: http://www.42draftdesigns.com/lancer.htm
Originally Posted by DrMerl
I try not to put anything in my field of vision, to me driving and seeing are more important than looking at guages. Too much blockage when turning left around a corner with pillar guages.
Originally Posted by jk_addict
Then you shouldn't have a wing on your car, cuz that blocks your rear view... Just like the wing, I'm sure I'll get used to bulky pillar quickly.
Yeah but I don't drive backwards.
Well, it seems that most people put them on the pillar so that's where I'll put mine. I have a CF boost gauge and dual gauge pod on order from fasterthanthem motorsports. I was going to get an EGT gauge, but for now it's too expensive and I have other things to worry about, but later on I will get an EGT gauge and have it installed.
i have an Autometer 3 pillar gauge pod with 3 52mm Greddy gauges... you will have some problems with the tweeter cover, just make sure that the color matches before you glue the tweeter cover on!!
I have seen some nice setups using pillar mounting that are very compact. They do not seem like they block the drivers view of the road at all. If you mount on the pillar you can use your peripheral vision and to me that seems safer than looking down below the windshield area. An alternative would be to mount idiot lights on the pillar and the actual guages down below where the stock radio is.
