Problem with Greddy Turbo Timer
Old Jun 29, 2004 | 11:32 AM
ZeroFrost's Avatar
I installed my greddy turbo timer, but now i cant use my keyless entry, i can only use my key to lock and unlock the car. Is that a normal thing with the turbo timer?
Old Jun 29, 2004 | 11:47 AM
ZeroFrost's Avatar
bump
Old Jun 29, 2004 | 11:49 AM
onlyr6's Avatar
Are you referring to the stock Mitsu keyless entry? It should work. Mine does with a GReddy TT.
Old Jun 29, 2004 | 11:51 AM
ZeroFrost's Avatar
mine doesnt.
Old Jun 29, 2004 | 12:30 PM
SinCityEvo's Avatar
Make sure you have the right harness.
Old Jun 29, 2004 | 01:06 PM
Failed_Senses's Avatar
I don't think you have the stock keyless entry then. I believe that you do have some sort of aftermarket alarm installed because that is the problem that most people have with turbo timers. A solution is to re-wire the ignition sensor of the alarm to the parking brake, so when the brake is up, the car is "off" to the alarm. Once the car is "off", you can lock you car and arm your alarm and all that jazz.
