2 pipes coming from exhaust manifold
Old Jul 18, 2004 | 09:30 AM
D1_EVO8's Avatar
hi guys im sure this has been brought up before but i searched and couldnt find anything.. ive seen pics of 2 small pipes on the stock exhaust manifold on non-u.s. model evos... the u.s. model exhaust manifold doesnt havethese pipes.. anyknow what there used for? EGR?
Old Jul 18, 2004 | 09:38 AM
Deceit's Avatar
There's a small little pipe to the right of the manifold on non-usdm models for the anti-lag system.
Old Jul 18, 2004 | 09:47 AM
evo_dadi's Avatar
yup thats the als for the evo that we didnt get to have
Old Jul 18, 2004 | 10:11 AM
Deceit's Avatar
No big loss there
Old Jul 18, 2004 | 10:20 AM
D1_EVO8's Avatar
i thought it was some sort of air injection system to clean up the exhaust fumes...
so its the anti lag system.. is the anti lag driver controlled? and are we (USDM) missing much? how does it come from the factory like that, wouldnt it cause massive unburned fuel out the taillpipe? not really tree friendly
thanks!
Old Jul 18, 2004 | 10:41 PM
WRC4ever's Avatar
It is the Secondary Air Supply System. The Non-US evos have a very, very, EXTREMELY small version of Anti-Lag. Some people say it is only active when in 5th gear at full speed for over 3 seconds, and letting the throttle out.
But others simply say the stock ECU does not really control this system, and it's only used in conjunction with aftermarket ECUs that support Anti-Lag.
Regards.
Old Jul 19, 2004 | 12:55 PM
plokivos's Avatar
picture anyone? this is interesting.
Old Jul 19, 2004 | 10:31 PM
lancerpartstrad's Avatar
damn, does this mean Jap HKS manifolds won't work on USDM evos? :
Old Jul 19, 2004 | 10:54 PM
SoR's Avatar
SoR
They should work just fine. You don't have to use ALS (also called bang-bang) and if you don't know what it is, it's better that you don't have it.
Old Jul 19, 2004 | 11:12 PM
well check out this picture of a stock US manifold, it looks like it does have ALS
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Jul 20, 2004 | 05:31 PM
Jorge T's Avatar
Looks like it's from the Dominican Republic. I doubt it is USDM.
Old Jul 20, 2004 | 05:55 PM
MalibuJack's Avatar
Ya know, does that also mean an Evo7 head is different than the USDM Evo 8?
Old Jul 20, 2004 | 07:29 PM
Jorge T's Avatar
I checked on mine the casting for the ALS is there but it is not drilled out.
Old Jul 20, 2004 | 07:37 PM
2k4EvoVIII's Avatar
I just got a aftermarket manifold for my evo 8 and it has those provisions on it. But it came with 2 plugs that can scew into them if they are not used.
Old Jul 21, 2004 | 04:33 AM
chuntington101's Avatar
it is a air injection system thta will clean up the exhaust gas and provied SOME anti lag capabilities but not the same as a bang-bang system would. by allowing air into the manifold when off the throttle, the theroy says you should keep the turbo spinning, but in practice i dout there would be any diffrence.
i have seen an aftermarket system fitted to a Ford RS200 that was every effective, but i think that system dumped all the boost into the exhaust manifold (or at least much more then this system does) and when combined with "bang-bang" anti-lag system kill all lag! wouldn't do the turbo much good but it was effective.
thanks Chris.
