Plastic undertray Q?
Old Aug 24, 2004 | 12:12 AM
evo81's Avatar
here's a retarded question for ya guys.is it alright to leave the plastic undertray off the car?saw this in the turbo mag with BIG AL's car in it.it showed a pic of the engine bay,but you could see the ground.would it cause any problems?
Old Aug 24, 2004 | 12:19 AM
Sentinal's Avatar
if its a daily driver your ganna get a lot of dirt and tar up on your engine not to mention rocks kicking up etc
Old Aug 24, 2004 | 12:21 AM
solarxclipse's Avatar
I took off mine after 1 month of owning my evo. Havent had any problems and it cools the engine from the bottom without it.
Old Aug 24, 2004 | 12:26 AM
vegasboy301's Avatar
ive been thinking about this as well. ive been having a few problems with it lately. from the car being so low...
Old Aug 24, 2004 | 12:40 AM
SinCityEvo's Avatar
Why take it off? It's lightweight plastic. Unless you are going to be working on your car on a regular basis.
I also remember that the under tray has a benefit of directing air to cool things down such as the TC and the brake rotors. If you look at the tray, it has channels for directing air.
Old Aug 24, 2004 | 10:22 AM
evo81's Avatar
thanks for input y'all.more is welcome though
Old Aug 24, 2004 | 11:57 AM
evoD's Avatar
that undertray also has quite an effect on the downforce at the front end. you should notice quite a difference traveling at freeway speeds with it off. it also helps to cool the engine by forcing the air to only travel in one direction through the engine bay and exit either through the hood vent or the rear near the firewall. without it, there is quite a bit of turbulence underneat the engine.
Old Aug 24, 2004 | 12:02 PM
1QWKEVO's Avatar
ya i'd leave it on as it aids in cooling and downforce... its basicly a diffuser for the front... but daily driving i dont think youll have a problem... if ur track racing and heating things up i'd put it back on
Old Aug 25, 2004 | 12:53 AM
trinydex's Avatar
if you want to change it somehow get a full front end splitter. it'll be one piece so you can easily take it off. plus it'll be very very good for aerodynamics.
Old Aug 25, 2004 | 03:15 AM
DocMortal's Avatar
I think it cools the engine down even better with it off...
The downpipe gets hit with a direct flow of air...but thats just me
Ill leave mine off..
Most modified evo's from Al's to sparco,to teins EVO leave it off....
Old Aug 25, 2004 | 01:45 PM
bolsen's Avatar
What's with those stupid stupid stupid plastic screws that DON'T unscrew!!! GRRR!
Old Aug 25, 2004 | 01:52 PM
stvbreal's Avatar
Damn thing folded back under the car during a high speed run. I stopped, ripped it off and tossed it in the ditch on the side of the road.
Old Aug 25, 2004 | 02:00 PM
Mxt 1's Avatar
hey is anyone else's cracked the hell up? i took a look at it the other day and there are just missing chunks all over the place. and i think it's the source of the rattling noises. it might be a bad idea to run with it off especially if your cam gear covers are off.
Old Aug 25, 2004 | 02:42 PM
SinCityEvo's Avatar
Plus all you guys in the snow belt, by keeping it on will keep you engine cleaner and free of salt splash from puddles. You have your starter right smack in the middle on the bottom.
Old Aug 25, 2004 | 03:10 PM
Ludikraut's Avatar
Might wanna read this (page 4 or so, IIRC): http://www.mitsubishi-motors.co.jp/PDF-E/evo8.pdf
Then think long and hard about how you plan on using your car before you take it off. IMO, for drag racing, I'd take it off, since it will save you some weight. However, for driving on the street and racing it around a track, I'd definitely leave it on (both to keep the car clean and for the downforce/air-channeling). I also have not seen an aftermarket splitter that adequately replaces the front undertray. I've seen the APR splitter and was somewhat underwhelmed. Autovation's splitter looks good, but it leaves the stock undertray in place... I'm hoping that the one Vishnu is working on will be better, but only time will tell.
l8r)
