URGENT!!!! Can this be fixed, or do I need a new radiator?
Old Aug 24, 2004 | 04:32 PM
Bobby12many's Avatar
While removing my radiator to install my MBC, I accidentaly did this to the radiator:
Can this be repaired with simply JBweld, or a trip to the Radiator repair shop? Other wise I need to hunt down a radiator ASAP!
Just one tiny pin sized hole, that peed all over my engine splash cover/diffuser.
please give your best adivce, as this is my current DD.
Old Aug 24, 2004 | 04:33 PM
nastea's Avatar
take it to a radiator shop, they can solder it shut
Old Aug 24, 2004 | 04:34 PM
Toddevo 8's Avatar
yea it can be fixed I did this to mine and they fixed it . if you need a new one go to radiator.com
Old Aug 24, 2004 | 04:35 PM
Wouldnt it be just as effective to use JBweld?
Old Aug 24, 2004 | 04:44 PM
VTECH8TR's Avatar
No JB Weld, i would get it welded shut.
Old Aug 24, 2004 | 04:46 PM
naucrx's Avatar
Hmm, why did you remove your radiator for an MBC install?
Old Aug 24, 2004 | 04:51 PM
Do you recall how much the service cost, and how fast it was done?
Old Aug 24, 2004 | 05:07 PM
I have large hands, and I just preferred to have all the room I needed to make it the cleanest install possible.
Turned out to be the messiest.
Old Aug 24, 2004 | 06:13 PM
VTECH8TR's Avatar
Bobby,
Their is a radiator for sale in the 4 sale forum. Good luck.
Old Aug 24, 2004 | 09:00 PM
propellerhead's Avatar
I used JBWeld to fix a leak in a pinch. I figured I'd get a new Koyo but I never did. I've been to 6 track days using the epoxy patch with no issues.
Old Aug 24, 2004 | 09:06 PM
Did you just use regular JB WELD?
Old Aug 24, 2004 | 09:37 PM
Thoe99's Avatar
Ha, I was able to install mine just by removing the plastic jack cover panel under the car.
Old Aug 24, 2004 | 09:42 PM
gofaster87's Avatar
It would be better to have it repaired at a shop so they can pressure test it afterwards, If you do it yourself at least get it tested to make sure there are no little leaks that will appear after reinstalling your radiator.
Old Aug 25, 2004 | 07:07 AM
SO sad......
I Still havent figured out how to remove those ******* clips/screws holding the underttray on
Old Aug 25, 2004 | 07:54 AM
scottatyamaha's Avatar
here is the guy that is selling his stock radiator.....for a great price too.
radiator for sale
