Rear differential lockup caused my accident?
Old Sep 9, 2004 | 11:55 AM
Evo H8's Avatar
I just got in an accident the other day. I'm fine, but my car is not. I was going around a a circle that merges onto a highway at about 30MPH - nothing even a stock evo couldnt handle. I've taken this corner at 80MPH before!
Anyways, just as I begin the turn, my back end starts going nuts. it starts kicking and skidding back and forth and then it completely kicks out and I am sideways. Luckily I was not going fast - i hit the guard rail with my front end at probly 10MPH. The first estimate for the damage was $17k!!!! the second estimate by another shop was $9k...
The roads were dry and I was not even going remotly quick. Did my rear differential lock up on me? I have heard of DSM's having recalls because of their rear differentials locking up.It was either that or an oil slick.
Anyone ever heard of an Evo rear diff locking up and the car spinning out???
Old Sep 9, 2004 | 12:04 PM
Silvercar's Avatar
What kind of tires are you runnng?
Old Sep 9, 2004 | 12:15 PM
YellowFever's Avatar
if he was going slow - what does that matter
Old Sep 9, 2004 | 12:18 PM
chrisw's Avatar
The DSM recall was on the center diff. The rear seal would fail leaking all the fuild in the transfer case causing it to lock up.
Did you lift the throttle in the middle of the corner?
Old Sep 9, 2004 | 12:21 PM
Silvercar's Avatar
My buddy wasnt going over 30 MPH and he spun it. **** tires.
Old Sep 9, 2004 | 12:24 PM
marksae's Avatar
Did you guys recently change your drivetrain fluids? It sounds like either your transfer case or rear diff locked up. That usually only happens if you leaked all your fluids out.
Old Sep 9, 2004 | 12:27 PM
UFO's Avatar
UFO
I've had that happen to me before, except it was raining and I was aquaplaning.... Maybe the shop can give some insight as to the cause? I've never heard of the rear diff locking up though.
Old Sep 9, 2004 | 12:29 PM
marksae's Avatar
Did you guys notice any abnormal drivetrain noises coming from the car right before the lockup happened? Dead/dying bearings usually whine really bad.
Old Sep 9, 2004 | 12:31 PM
JaguarS4R's Avatar
I spun out once just taking a slow turn, maybe 15mph and it spun 3 times in the wet. Maybe b/c it had armor-all on it
Old Sep 9, 2004 | 01:57 PM
Evo H8's Avatar
I heard no weird noises, and I didnt let up on the throttle. I've never seen any fluids leaking from my car before. I've had the back end kick out a little bit before while taking turns FAST, but they were easily correctable. I am on stock tires that have about 2000 miles on them. It COULD have been some fluid in the road, I dunno. If it wasnt such a busy intersection I would go back and check.
Thoe99
378
Jul 30, 2018 05:56 PM
HatrixMouse
14
Sep 27, 2016 09:42 AM
girth5785
Jul 27, 2016 08:27 AM
Gazika
Sep 19, 2011 12:48 PM
vtluu
15
Feb 7, 2008 09:40 PM
