-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   OK, I've tried searching but... (https://www.evolutionm.net/forums/evo-general/208476-ok-ive-tried-searching-but.html)
heSOshAdy Jun 26, 2006 03:58 PM
I need some input here. This is going to sound strange because it's hard to describe. I will try to put it in words to the best of my ability:
When I shift hard out of 1st gear to 2nd or 2nd to 3rd sometimes (again, I dont know what triggers this) I hear an "engine revving" noise before I hear my BOV "whoosh." Normally, I should just hear my BOV going off instantly after I shift.
Anyone know what's causing this or if this is just normal?
Any help would be great.
MBaran Jun 26, 2006 04:04 PM
wastegate.
its what bleeds off the excess turbo pressure to prevent overboosting. sounds sort of like revving before you would shift
heSOshAdy Jun 26, 2006 04:05 PM
Yes! It sounds like revving before the BOV goes off. So tell me it's normal so I can sleep better tonight =)
Is it me, or does this cause you to shift a bit slower?
MBaran Jun 26, 2006 04:05 PM
of course its normal. if it didnt do that you would make boost until something blew up.
fusionchicken Jun 26, 2006 04:27 PM
i believe it's the wastegate as well.
Warrtalon Jun 26, 2006 04:31 PM
Normal? I've never even heard of what MBaran is talking about. There should be no sound coming from your wastegate and no revving noise when you shift. Not sure where that came from. Maybe if you had an external wastegate, then all that excessive noise under boost would make sense, but by no means should you randomly hear the wastegate. I'm not saying the wastegate doesn't open in order to regulate the boost, but I have no idea how you'd hear it. I've certainly never heard mine, and there should be nothing slowing down your shifting.
There is some other problem here that must be diagnosed. Didn't you say this happens WHEN you shift? As in, you press the clutch, hear the "rev" noise, then the whoosh, then you go into the next gear? That sounds like an awful long time. If I shift quickly like when drag racing, the time between the two is mere milliseconds with only enough time for a quick chirp from the BOV. Are you talking about daily driving and slow shifting?
MBaran Jun 26, 2006 06:59 PM
when i go WOT i can hear my waste gate on my IX loud and clear. it depends how on the gas I am, and what RPM, but its audible as all. I know wastegate sounds. I think hes confused on how to word his sentance.
but to recap. i can hear my IX's wastegate. I know exactly when it kicks in. kthx
Rnm Jun 26, 2006 07:06 PM
I can't hear my wastegate, all that I hear is my turbo.
MBaran Jun 26, 2006 07:08 PM
with stock exhaust i was able to hear it. with TBE +02+manifold, not so much any more. but on a quiet night with the windows up, i knew it was the WG opening.
Warrtalon Jun 26, 2006 07:09 PM
RNM, I think that's what they're referring to. You can hear the WG start to open, especially if you do a part throttle slow building of boost. It goes woooooooOOOOOOOOOOSSSSSSHHH, etc, which is the sound of the turbo spooling, but you can hear the WG opening. However, that sounds nothing like the engine revving, and it by NO MEANS happens after the shift.
