OK, I've tried searching but...
Old Jun 26, 2006 | 03:58 PM
heSOshAdy's Avatar
I need some input here. This is going to sound strange because it's hard to describe. I will try to put it in words to the best of my ability:
When I shift hard out of 1st gear to 2nd or 2nd to 3rd sometimes (again, I dont know what triggers this) I hear an "engine revving" noise before I hear my BOV "whoosh." Normally, I should just hear my BOV going off instantly after I shift.
Anyone know what's causing this or if this is just normal?
Any help would be great.
Old Jun 26, 2006 | 04:04 PM
MBaran's Avatar
wastegate.
its what bleeds off the excess turbo pressure to prevent overboosting. sounds sort of like revving before you would shift
Old Jun 26, 2006 | 04:05 PM
heSOshAdy's Avatar
Yes! It sounds like revving before the BOV goes off. So tell me it's normal so I can sleep better tonight =)
Is it me, or does this cause you to shift a bit slower?
MBaran's Avatar
of course its normal. if it didnt do that you would make boost until something blew up.
Old Jun 26, 2006 | 04:27 PM
fusionchicken's Avatar
i believe it's the wastegate as well.
Old Jun 26, 2006 | 04:31 PM
Warrtalon's Avatar
Normal? I've never even heard of what MBaran is talking about. There should be no sound coming from your wastegate and no revving noise when you shift. Not sure where that came from. Maybe if you had an external wastegate, then all that excessive noise under boost would make sense, but by no means should you randomly hear the wastegate. I'm not saying the wastegate doesn't open in order to regulate the boost, but I have no idea how you'd hear it. I've certainly never heard mine, and there should be nothing slowing down your shifting.
There is some other problem here that must be diagnosed. Didn't you say this happens WHEN you shift? As in, you press the clutch, hear the "rev" noise, then the whoosh, then you go into the next gear? That sounds like an awful long time. If I shift quickly like when drag racing, the time between the two is mere milliseconds with only enough time for a quick chirp from the BOV. Are you talking about daily driving and slow shifting?
Old Jun 26, 2006 | 06:59 PM
MBaran's Avatar
when i go WOT i can hear my waste gate on my IX loud and clear. it depends how on the gas I am, and what RPM, but its audible as all. I know wastegate sounds. I think hes confused on how to word his sentance.
but to recap. i can hear my IX's wastegate. I know exactly when it kicks in. kthx
Old Jun 26, 2006 | 07:06 PM
Rnm's Avatar
Rnm
I can't hear my wastegate, all that I hear is my turbo.
Old Jun 26, 2006 | 07:08 PM
MBaran's Avatar
with stock exhaust i was able to hear it. with TBE +02+manifold, not so much any more. but on a quiet night with the windows up, i knew it was the WG opening.
Old Jun 26, 2006 | 07:09 PM
Warrtalon's Avatar
RNM, I think that's what they're referring to. You can hear the WG start to open, especially if you do a part throttle slow building of boost. It goes woooooooOOOOOOOOOOSSSSSSHHH, etc, which is the sound of the turbo spooling, but you can hear the WG opening. However, that sounds nothing like the engine revving, and it by NO MEANS happens after the shift.
H8ted1488
Driving Techniques
25
Jan 16, 2010 12:55 PM
chase123
Feb 9, 2009 09:00 AM
hardt45
Apr 30, 2005 10:21 AM
Chan
Oct 31, 2003 09:16 AM
Chan
Oct 28, 2003 12:23 PM
