Rattling and dangling sounds while shifting gear 1st to 2nd.
Old Oct 30, 2003 | 10:06 PM
Chan's Avatar
Unhappy Rattling and dangling sounds while shifting gear 1st to 2nd.
I still have some problem,
While Im shifting gear from 1 st to 2nd, I hear metal dangling and lapping sound under my feet and seat.
If I shift very smoothly with luck, there's none.
but most of time, I keep hearing those sound..
I think something's loosend up,
What should I check with?
Old Oct 30, 2003 | 10:31 PM
5StarSuzuki's Avatar
In Timeout
Sounds normal... You have an AWD car that makes noises.
Old Oct 30, 2003 | 10:40 PM
Chan's Avatar
Are you ssssssure??
'cause if it's normal, It has to be sounding everytime, but not.
Im just gonna look up under my car, if something's loosend,.
Old Oct 30, 2003 | 10:41 PM
boostedwrx's Avatar
The first to second pull sucks *****. Heres a tip - put pressure on the shifter with your fingers or the palm of your hand before you are ready to clutch in. As soon as you clutch in the pressure your hand is giving the shift knob should guide you right to you second gear synchros and it should go right in. Ive found the slower i shift into second, the crappier it feels. The fast I shift into second, the better it feels. At high rpm my car loves behing shifted, at low rpm the clogs feel mighty nasty.
Old Oct 30, 2003 | 10:46 PM
Chan's Avatar
that's what Im talkin about,
BUT !!
the thing is when my car shakes, there's something under my car shakes too!! I am guessing that is downpipe or chasis something.
they are lapping together, so it makes "tung, tung, tung" sound.
Old Oct 31, 2003 | 12:34 AM
leaveit2bevo1's Avatar
In Timeout
I get that sound all the time mostly in reverse. I think its the clutch it dosent disingage very well so it clunks.
Old Oct 31, 2003 | 12:56 AM
CarPhoto.net's Avatar
I must have kryptonite sycros because It shifts smooth and makes cool clamp noises like a strong tranny should.
Old Oct 31, 2003 | 09:05 AM
tpm17's Avatar
I've got the same damn clanking noises and I'm embarassed when people realize it's my car that's making the noise.
Old Oct 31, 2003 | 09:16 AM
Dale_K's Avatar
Take it to the dealer and ask them about it. I don't get any noise when shifting no matter what gear. It is slightly notchy when I first drive it in cold weather but even then there is no noise.
Of course there is a normal whining noise at certain speeds but it has nothing to do with shifting gears.
Czarcasm
13
Nov 24, 2013 10:49 AM
EvolutionTheory
Nov 28, 2009 06:52 PM
jvans04
Aug 5, 2006 02:33 PM
heSOshAdy
Jun 26, 2006 07:09 PM
rt turbo
21
Jun 10, 2003 03:07 PM
