What's wrong with my Defi gauges.
So all the sudden on my way home from work I noticed that my Defi oil pressure gauge stopped working. It's lit up and go on/off just fine but it will not read anything and set at 0 psi & scared the Sh1t out of me:crap:. The alarm warning did not go off either. Is there a way to reset that.:helpme::helpme::helpme::helpme:
have you checked to make sure everything is hooked up fine and nothing might have come undone?
gonna have to check everything, something had to of come loose
if it stopped working either the wire from the gauge to the link is f'ed up or the wire from the sensor to the link is f'ed up.
if it lights up but does not work i would start from the sensor to the link box. if is does not light up or work then strt from the gauge to the link box |
ya I will try that. like you said it might be the sensor but I am not sure yet. My boost & EGT are working fine, and I hope I don't need another control unit this one is only 16 month old.
oil pressue hooks up with a hose.....same with defi correct or no?....if it is a hose dont drive the car because u could be shooting oil out of the line
no man it's a wired sensor.
Originally Posted by EVIL MR
(Post 5510672)
do you have a block adapter with your oil pres sensor? and does it beep at all when it sits at 0?
Originally Posted by krazirob
(Post 5511611)
Is there anyway to replace the defi sensor with another kind. Defi sensor is like $170.
I got Defi gauges, but I wouldn't suggest mixing and matching sensor with the gauges. You might be able to find a cheaper one somewhere else though, thats authentic. Try "Private For Sale" or Ebay perhaps? =)
But first things first, just make sure it wasn't a botched install. Like someone else said, a wire could've just gotten loose. Also, make sure the wires that run from the sensor didn't rub on something in the engine bay to cut that wire or short circuit it. Bet you some chocolate chip cookies thats what it is. |
No all the wires are good. it worked fine for over a year and then stopped. Even on ebay they are 170+
More info on that short circuit thing!
(Post 5894184)
First thing I would check is the pressure sender. You have a multimeter? You may want to get one. |
| All times are GMT -7. The time now is 08:14 AM. |
