What's wrong with my Defi gauges.
So all the sudden on my way home from work I noticed that my Defi oil pressure gauge stopped working. It's lit up and go on/off just fine but it will not read anything and set at 0 psi & scared the **** out of me
. The alarm warning did not go off either. Is there a way to reset that.
if it stopped working either the wire from the gauge to the link is f'ed up or the wire from the sensor to the link is f'ed up.
if it lights up but does not work i would start from the sensor to the link box.
if is does not light up or work then strt from the gauge to the link box
ya I will try that. like you said it might be the sensor but I am not sure yet. My boost & EGT are working fine, and I hope I don't need another control unit this one is only 16 month old.
I got Defi gauges, but I wouldn't suggest mixing and matching sensor with the gauges. You might be able to find a cheaper one somewhere else though, thats authentic. Try "Private For Sale" or Ebay perhaps? =)
But first things first, just make sure it wasn't a botched install. Like someone else said, a wire could've just gotten loose.
Also, make sure the wires that run from the sensor didn't rub on something in the engine bay to cut that wire or short circuit it.
Bet you some chocolate chip cookies thats what it is.
First thing I would check is the pressure sender. You have a multimeter? You may want to get one.
