-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Fog Lights don't work, help! (https://www.evolutionm.net/forums/evo-general/347618-fog-lights-dont-work-help.html)
fugiwara May 25, 2008 06:09 PM
Last night I took out my fog light switch to paint the bulb red, I accidentally break the tiny bulb but I replace it with another one from from headlight adjustment.
I put everything back and my fog lights don't turn on.
I check all the fuse, inside the engine bay and underneath the driver side and they all look fine. I checked the fog light bulbs and they look ok too.
I have 05 MR so the fog light switch is next to the headlight level adjustment switch.
Please help me out here, thanks in advance.:mitsu:
fugiwara May 25, 2008 09:20 PM
bump for help
fugiwara May 25, 2008 11:25 PM
I am suspecting the bulbs are no good, but filament looks attached, but I've heard even tho they look fine doesn't means they'll work.
fugiwara May 26, 2008 07:55 AM
somebody must know this, please share your opinion, if you have any insight welcome
fugiwara May 26, 2008 12:22 PM
up
fugiwara May 26, 2008 06:02 PM
help needed please
_Evo7_ May 26, 2008 06:07 PM
maybe its worth just trying another bulb. u said all the fuses looked fine, did u only check them visually?
fugiwara May 27, 2008 06:11 AM
I check the bulb visually, but fuses, I took out other fuse and switch them around.
fugiwara May 27, 2008 03:38 PM
I still need help!
S4STIEVO May 27, 2008 06:04 PM
was the power on when u removed the switch. you could have damged the switch it self. or a relay.
Evoryder May 27, 2008 06:05 PM
fuse under hood?
fugiwara May 29, 2008 01:00 AM
Yup it's the switch itself, today I had chance to swap switch with my buddy.
holler mcdollar May 29, 2008 09:29 AM
so it's fixed?
fugiwara May 30, 2008 09:33 PM
Originally Posted by holler mcdollar (Post 5713691)
so it's fixed?
well, I just have to get a new switch for it, but I know the problem it's switch.
