Fog Lights don't work, help!
Old May 25, 2008 | 06:09 PM
fugiwara's Avatar
Question Fog Lights don't work, help!
Last night I took out my fog light switch to paint the bulb red, I accidentally break the tiny bulb but I replace it with another one from from headlight adjustment.
I put everything back and my fog lights don't turn on.
I check all the fuse, inside the engine bay and underneath the driver side and they all look fine. I checked the fog light bulbs and they look ok too.
I have 05 MR so the fog light switch is next to the headlight level adjustment switch.
Please help me out here, thanks in advance.
Old May 25, 2008 | 09:20 PM
fugiwara's Avatar
bump for help
Old May 25, 2008 | 11:25 PM
fugiwara's Avatar
I am suspecting the bulbs are no good, but filament looks attached, but I've heard even tho they look fine doesn't means they'll work.
Old May 26, 2008 | 07:55 AM
fugiwara's Avatar
somebody must know this, please share your opinion, if you have any insight welcome
Old May 26, 2008 | 12:22 PM
fugiwara's Avatar
up
Old May 26, 2008 | 06:02 PM
fugiwara's Avatar
help needed please
Old May 26, 2008 | 06:07 PM
_Evo7_'s Avatar
maybe its worth just trying another bulb. u said all the fuses looked fine, did u only check them visually?
Old May 27, 2008 | 06:11 AM
fugiwara's Avatar
I check the bulb visually, but fuses, I took out other fuse and switch them around.
Old May 27, 2008 | 03:38 PM
fugiwara's Avatar
I still need help!
Old May 27, 2008 | 06:04 PM
S4STIEVO's Avatar
was the power on when u removed the switch. you could have damged the switch it self. or a relay.
Old May 27, 2008 | 06:05 PM
Evoryder's Avatar
fuse under hood?
Old May 29, 2008 | 01:00 AM
fugiwara's Avatar
Yup it's the switch itself, today I had chance to swap switch with my buddy.
Old May 29, 2008 | 09:29 AM
holler mcdollar's Avatar
so it's fixed?
Old May 30, 2008 | 09:33 PM
fugiwara's Avatar
Originally Posted by holler mcdollar
so it's fixed?
well, I just have to get a new switch for it, but I know the problem it's switch.
EGbeater
23
Apr 20, 2015 10:46 AM
yorT
Oct 19, 2010 06:57 PM
russlancer
Lancer Troubleshooting
Mar 13, 2009 05:03 AM
bdan88
Sep 3, 2008 03:56 PM
MattevoVIII
Nov 13, 2007 08:25 PM
