Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Need Help Installing Fog Lights :-/
Old Jun 5, 2008 | 04:14 PM
bdan88's Avatar
Ok... So I bought my fog lights on ebay and they are almost exactly like the real OEM fog lights that come on the lancer GTS's. On the box they are called ESUSE Original-type Fog Lamp for Mitsubishi lancer 2008. I had no problem setting up the harness for the lights, removing the front bumper to set up the wires that connect to the bulbs, or installing the switch that goes inside the car. All I need is some electrical and wiring advise. I don't know how to connect my switch on the inside of the car to the rest of the wires in the engine bay (how to i get it past the firewall). And I'm not to sure how to hook up my lights to a power source. If there is anyone that can help me I would really appreciate it!
Old Jun 5, 2008 | 06:23 PM
kalpakiotis's Avatar
I'll be trying to fish a wire through the firewall for my Lows, so that I can bypass the DRL stuff. If i find a convenient spot, I'll take a picture. I'm hopping I can get it through behind the steering column, but i have a feeling i'll be goin back behind the air filter somewhere. We'll see what happens when i start taking stuff apart.
Old Jun 10, 2008 | 08:18 PM
hungryhung's Avatar
let us know how it all works out...i see them on ebay for like 100
Old Jun 15, 2008 | 09:25 AM
bdan88's Avatar
In order to run the wires behind the bumper you have to remove the entire bumper which can be found somewhere on these forums.
As for the rest of the electrical work there is a rubber grommet behind the engine against the firewall.... all you have to do is cut a small slit in the side of it and feed your wires through that hole. That is how the manufacturers fed all their electrical lines so be careful. It will come out on the other side towards the middle of the dash. if you're looking under your dash from the drivers seat you should see a small cardboard opening where the wireswill come out! From there you can make it reach your switches.
The fog lights came out great! The ebay ones are good because your basically paying half of what mitsubishi is charging and you can use the rest of the money switching to HID's!
Old Jul 8, 2008 | 09:59 PM
sire__1988's Avatar
hey bdan88 i just recieved my set of the exact same fogs.. i got the whole installation done but only thing i can't figure is where to properly ground and where to hookup up the green wire for my switch..If you can post some pics of what you did, that would be greatly appreciated.
Old Aug 21, 2008 | 02:25 PM
nanonyc's Avatar
what I would do is get a relay... put your ground to a regular ground... and the relay switched to the low side lights... so whenever you turn your small lights on... you FOGS would come up ...now i you like me or some other ppl dont like me sometimes dont wanna have it on is that just put the swith inside your car... for ex.
1.- Ground to ground or chassis.
2.- Positive To Batery or other source of Positive
3.- Switch cable routed to the inside of the car.. to a switch then bring it back to the small bean positive.
reason:
your inside switch will only work if your Low beans are on... this protect you from leaving your FOGs light accidentaly on... and drain your Batt.
that is what I would do... again... please be sure.. that you get your rights wire...
Old Aug 28, 2008 | 09:14 PM
pashunka's Avatar
so guys can anyone right a small how-to with pics? i am really not very good at it my self but if i have some pics i should be fine.
basically right now i have my fogs connected to the low beams and they also run as drls together with low beams which i don't like. what i want to do is put a switch and will be able to turn them on and off whenever i want, not depending on drls.
Old Aug 30, 2008 | 11:48 AM
CamShaft's Avatar
sounds like you need an automotive technician to be doing this for you. Are you sure you should be setting this up yourself?
Old Aug 30, 2008 | 03:58 PM
pashunka's Avatar
well my friend is a technician and if i get a diagram or some pics he should be able to do it himself
Old Sep 3, 2008 | 03:56 PM
pashunka's Avatar
do you guys know anybody who has DE and has bought fogs for it? they should have a guide on how to install them. If you know someone, is there any way they can post a install guide?
MasterAK
Lancer How Tos / Installations
58
Aug 19, 2020 10:45 AM
myersOS16
Outlander Sport
14
Jul 26, 2019 03:41 PM
EvokidIX
Mar 12, 2016 04:08 PM
rdc
May 18, 2014 12:10 AM
marshall15
Aug 21, 2006 07:19 PM
