fog lights off ebay wired to factory wire harness help!!!!
hey guys i install a oem fog light off of ebay. http://cgi.ebay.com/ebaymotors/04-05...QQcmdZViewItem
i have an 05 ES by the way.
anyway i hard wire it to my electrical with the instruction and it is good.
anyway this weekend i saw the factory fog light wire harness clipped in the lower front crash bar under the radiator. and under the console where you put the switch. i dont know if someone has already tried using it with oem fog light kits off the stealership. want to know if how could i wire the fog lights off ebay to the factory wire harness to have a flush clean look. thanks
I'm pretty sure all the necessary wiring is there, except the short piece that goes from the connector you found out to each fog light.
The short wiring harness you'll need is part # MN124940. The relay is MR538851. The switch for the dashboard is MR190951. Your front ECU should have the necessary circuit in it already.
Good luck!
Good luck!
mitsu actually wired all the cars the same, i have a buddy with an 06 ES and it has the plug in the trunk for the infinity sub. and he has the clips for fog lights. wonder why mitsu doesnt make it an option to get fogs on an es or an oz...
EvokidIX
Mar 12, 2016 04:08 PM
