-   Evo General (https://www.evolutionm.net/forums/evo-general-11/)
-   -   Hvac problems on blowing air on 4. 1,2,3 all don't work. (https://www.evolutionm.net/forums/evo-general/409755-hvac-problems-blowing-air-4-1-2-3-all-dont-work.html)
W_evo8 Mar 27, 2009 09:09 AM
My blower motor went out and I replaced it today. Theres only power going to it when I turn the knob to 4. 123 don't work. Any Ideas? Please only reply if you know what you're talking about.
EatSleepBoost Mar 27, 2009 10:17 AM
uv got a bad blower motor resistor. i work at a gm dealer and they are REAL common. not sure where it is located on our cars but that is what you need.
JJsEvo8 Mar 27, 2009 11:41 AM
I have a slightly different issue... my gauges are incorrect, I have to turn it to Defrost to get heat, even when the other dial is on heat...
VRSF Tiago Mar 27, 2009 11:50 AM
Yep, definitely the blower motor resistor.
W_evo8 Mar 27, 2009 02:00 PM
I was thinking something like that, I just need to know where to find it.
Anyone know where the blower motor resistor is?
Kracka Mar 27, 2009 03:06 PM
I'd suspect the actual switch on the dash.
W_evo8 Mar 27, 2009 03:16 PM
Yeah I might go raid a lancer at a junk yard and replace it all, I've been freezing my ass off here in Jersey and then I get in my car heat full blast then its too hot gets cold, then too hot and have too keep messing with it every 5 minutes.
Still if anyone knows for sure let me know either in this thread or through PM. Thanks, -Wevo
heel2toe Mar 28, 2009 09:58 PM
If only the highest setting works then theres a 99% chance its the blower motor resistor. This is because on the highest setting the resistor is completely bypassed.
SWOLN Mar 29, 2009 07:04 AM
In the mean time just move the temp selector to the middle, give or take, to suit your comfort zone.
barneyb Mar 29, 2009 01:39 PM
Low, medium low and medium high blower speeds all use the resistor block. Low feeds through three resistors, medium low two resistors and medium high just one resistor. Lose this last resistor and you lose all three speeds. The resistor block also has a fuse in it. Lose the fuse and lose all three lower speeds.
According to the shop manual the resistor block is somewhere between the blower motor and the console and has a 4-wire plug on it. It is attached to the ducting by 2 screws. I looked under but didn't find it.
