Hvac problems on blowing air on 4. 1,2,3 all don't work.
Old Mar 27, 2009 | 09:09 AM
W_evo8's Avatar
My blower motor went out and I replaced it today. Theres only power going to it when I turn the knob to 4. 123 don't work. Any Ideas? Please only reply if you know what you're talking about.
Old Mar 27, 2009 | 10:17 AM
EatSleepBoost's Avatar
uv got a bad blower motor resistor. i work at a gm dealer and they are REAL common. not sure where it is located on our cars but that is what you need.
Old Mar 27, 2009 | 11:41 AM
JJsEvo8's Avatar
I have a slightly different issue... my gauges are incorrect, I have to turn it to Defrost to get heat, even when the other dial is on heat...
Old Mar 27, 2009 | 11:50 AM
VRSF Tiago's Avatar
Yep, definitely the blower motor resistor.
Old Mar 27, 2009 | 02:00 PM
W_evo8's Avatar
I was thinking something like that, I just need to know where to find it.
Anyone know where the blower motor resistor is?
Old Mar 27, 2009 | 03:06 PM
Kracka's Avatar
I'd suspect the actual switch on the dash.
Old Mar 27, 2009 | 03:16 PM
W_evo8's Avatar
Yeah I might go raid a lancer at a junk yard and replace it all, I've been freezing my *** off here in Jersey and then I get in my car heat full blast then its too hot gets cold, then too hot and have too keep messing with it every 5 minutes.
Still if anyone knows for sure let me know either in this thread or through PM. Thanks, -Wevo
Old Mar 28, 2009 | 09:58 PM
heel2toe's Avatar
If only the highest setting works then theres a 99% chance its the blower motor resistor. This is because on the highest setting the resistor is completely bypassed.
Old Mar 29, 2009 | 07:04 AM
SWOLN's Avatar
In the mean time just move the temp selector to the middle, give or take, to suit your comfort zone.
Old Mar 29, 2009 | 01:39 PM
barneyb's Avatar
Low, medium low and medium high blower speeds all use the resistor block. Low feeds through three resistors, medium low two resistors and medium high just one resistor. Lose this last resistor and you lose all three speeds. The resistor block also has a fuse in it. Lose the fuse and lose all three lower speeds.
According to the shop manual the resistor block is somewhere between the blower motor and the console and has a 4-wire plug on it. It is attached to the ducting by 2 screws. I looked under but didn't find it.
skiracer
Sep 23, 2017 08:07 PM
Evodetailer123
Aug 20, 2015 06:47 AM
coollol123
Dec 30, 2011 08:22 PM
YeaIbOOst
For Sale - Cars For Sale
18
Dec 11, 2008 06:44 PM
Dannievo
Dec 3, 2007 06:51 PM
