tell me what's next?
Ideas on what I should do to my VIII next? Currently everything done is small...
-short ram intake -ACT clutch/flywheel -Walboro 255lph fuel pump - Turbo XS 3" exhaust w/test pipe -manual boost controller/prosport egt/boost gauges - Ivey Tuned 314 whp now I wanna be at anywhere from 380-400 whp Also, I wanna start installing things myself...Let me know if people are willing to help if I get parts |
depending on your budget I would say injectors and cams then a retune.
Originally Posted by djslik408
(Post 7401244)
uicp and licp if you dont already have it.. go with cams and a good tune
Lots of boost, cams, intercooler and piping, should be around your goals.
cams, injectors, E85!
e85 and IC piping
Cams, intercooler, 9 dv & a tune to start. Wont net u your goals but u will b in right direction.
i'd say fmic, licp, injectors and retune for e85 -- that's the cheapest route to get to those numbers which should be possible on an md..if e85 isn't available tune for 93, add some kelford 272's, maybe an fp wga, more boost. that will get you close.i'd leave out the uicp unless you want to spend more money on something that won't really net you gains worth the cost of the part.
intercooler and piping and cams with a retune
No meth fans? Headstuds, meth kit, tune with map switching.
Please read the moding sticky and the $100 at a time post.
| All times are GMT -7. The time now is 03:51 PM. |
