tell me what's next?
Old Aug 16, 2009 | 09:39 AM
BoostIt's Avatar
Ideas on what I should do to my VIII next? Currently everything done is small...
-short ram intake
-ACT clutch/flywheel
-Walboro 255lph fuel pump
- Turbo XS 3" exhaust w/test pipe
-manual boost controller/prosport egt/boost gauges
- Ivey Tuned
314 whp now
I wanna be at anywhere from 380-400 whp
Also, I wanna start installing things myself...Let me know if people are willing to help if I get parts
Old Aug 16, 2009 | 10:49 AM
djslik408's Avatar
depending on your budget I would say injectors and cams then a retune.
Old Aug 16, 2009 | 11:50 AM
XSivPSI's Avatar
He doesn't need injectors yet. Not on the stock turbo. I've got all that and cams and stock injectors are plenty.
Old Aug 16, 2009 | 12:47 PM
sleeper04's Avatar
uicp and licp if you dont already have it.. go with cams and a good tune
Old Aug 16, 2009 | 12:57 PM
JakeTheVIII's Avatar
Lots of boost, cams, intercooler and piping, should be around your goals.
Old Aug 16, 2009 | 01:07 PM
06RedRalli's Avatar
cams, injectors, E85!
Old Aug 16, 2009 | 01:13 PM
katchup's Avatar
e85 and IC piping
Old Aug 16, 2009 | 01:30 PM
Cali2MDevo8's Avatar
Registered User
Cams, intercooler, 9 dv & a tune to start. Wont net u your goals but u will b in right direction.
Old Aug 16, 2009 | 02:30 PM
CoMoEvo's Avatar
i'd say fmic, licp, injectors and retune for e85 -- that's the cheapest route to get to those numbers which should be possible on an md..if e85 isn't available tune for 93, add some kelford 272's, maybe an fp wga, more boost. that will get you close.i'd leave out the uicp unless you want to spend more money on something that won't really net you gains worth the cost of the part.
Old Aug 16, 2009 | 07:35 PM
evo003's Avatar
intercooler and piping and cams with a retune
Old Aug 16, 2009 | 07:48 PM
JohnDoe1984's Avatar
No meth fans? Headstuds, meth kit, tune with map switching.
Old Aug 17, 2009 | 03:43 AM
Smike's Avatar
Please read the moding sticky and the $100 at a time post.
