Evo IX Oil Filter Housing Question
I have a IX with a cracked oil filter housing, I wanted to know where i could get this part from and how hard is it to change..Also is there a how to on how to change the oil filter housing...thanks
Where is the crack in the housing? Down at the bottom near the base plate or up higher? How in the hell did that happen?
Wow.... still under warranty? Unless you broke it
I'm not sure if the VIII's and the IX's share the same oil filter housing, if that is the case you may be able to get the part from these guys: http://machevo.com/oilfihoforev.html
Good luck in getting the car fixed! |
its crack alittle where you can take out the plug and screw in the oil feed line
Angles217 how did you get it fixed? Did you find a write up on how to or did you take it into a shop? Something similiar has happened to mine and needs to be replaced.
