Evo IX Oil Filter Housing Question
Old Sep 12, 2009 | 11:30 PM
Angles217's Avatar
I have a IX with a cracked oil filter housing, I wanted to know where i could get this part from and how hard is it to change..Also is there a how to on how to change the oil filter housing...thanks
Old Sep 14, 2009 | 02:07 PM
BoostIsMyDrug's Avatar
Where is the crack in the housing? Down at the bottom near the base plate or up higher? How in the hell did that happen?
Old Sep 14, 2009 | 06:30 PM
GTijoejoe's Avatar
Wow.... still under warranty? Unless you broke it
Old Sep 14, 2009 | 06:37 PM
JRB_EVO's Avatar
I'm not sure if the VIII's and the IX's share the same oil filter housing, if that is the case you may be able to get the part from these guys: http://machevo.com/oilfihoforev.html
Good luck in getting the car fixed!
Old Sep 14, 2009 | 09:10 PM
Angles217's Avatar
its crack alittle where you can take out the plug and screw in the oil feed line
Old Dec 26, 2012 | 05:48 PM
NODAKevo's Avatar
Angles217 how did you get it fixed? Did you find a write up on how to or did you take it into a shop? Something similiar has happened to mine and needs to be replaced.
Admin2304
Aug 9, 2017 11:13 AM
KJS
May 10, 2016 07:40 AM
Manderson
Sep 23, 2015 05:48 PM
awdturboscott
Nov 29, 2012 08:48 AM
gudmundur
Dec 13, 2008 07:04 PM
