3 ACD Lights And Anti Lock On??
Ok, so coming home from philly last night i realized that all my acd lights were frozen on and my anti lock light was frozen on. The only reason why i didn't notice it at first is because i usually leave my tactrix cables plugged in so they always blink.
Now since there unplugged i get a frozen anti lock brake like and my 3 acd lights are on.. I search and only came up with replacing the acd pump. But i am not sure why the antilock light is on.. What i have tried: 1) Turn Car on and off.. 2) Unplugged ground from battery to reset everything. As soon as i turn the car on the lights pop up and are still the same. |
from what i understand various sensors and electrical things in the car can make the acd lights act up. i would first check abs codes as they are much easier to scan for, and try to fix that and see if the acd lights go away as a result. if that doesnt work it could also be that the pump just needs to be bled properly. worst case, find a mitsu dealer with the "Mut" tool and have them scan your ACD ecu for $95 and know for sure. good luck
underneath the cup holders there are 2 sensors that go down basically under the car! one must have came unplugged my car had those on after i pulled it out for the winter and i finally found out one of those sensors was unplugged! if its not that you'll have to find the code and it may be one of the wheel sensors... but there are a couple sensors under the cup holders so just look really good... so just take the center console out and make sure everything under there is plugged in really good!
I had that happen with the ACD lights come on after i had my clutch changed. Turned out that they didnt fill the acd fluid up. fillled it up and lights went out. but Im sure you checked the fluid level already
Read the owner's manual..
If all 3 lights are illuminated have it diagnosed and serviced. It could be a number of issues such as bad relay or bad pump. Also, if the clutch was changed, the acd needs to be reset. As for the anti lock light, I am unsure. Sometimes a combination of lights means a certain issue. Bring it to Mitsu and have them diagnose it. ACD and your brakes are essential components to the car so if there is something wrong, it needs to be fixed. |
i've had the 3ACD light come on while i was driving. i would pull over turn off the car and turn it back on. it would go away. its done it to me couple of times. but now it doesnt do it.
Originally Posted by 06GraphiteEvoIX
(Post 8178855)
When i turn the key to the on position i'm pretty sure i hear the pump fire up. But it may be something else. I dunno i'll check over everything today and report back. Too bad i don't have the money for Mitsu to rip me a new one on scanning the code. So if i can't fix it I'll be driving like this for some time. By the way i don't really feel any difference on the road or off the road (dirt) for that matter. |
[quote=eXtreme-Speed;8181942]I'm going to try this because i had the cup holder off the day before it happened so i am thinking i might have knocked something loose. [quote]
i gaurantee thats what happened! same thing with me just unplug everything and plug them all back in... i hope it solves your problem! |
Lots of threads on this topic. When I purchased my car it had this issue and got it resolved through the help provided by reading the threads on it!
Originally Posted by Ryan.Kauz
(Post 8182502)
(Post 8178855)
Look in to this! i drove around 8000 miles before I found out what the issue was. |
bump...what was the issue? I just had the same problem. Switched into Gravel mode from Tarmac and a few seconds later the anti lock and ACD came on. Anti lock stays on but ACD only comes on once I get moving. I am going to check all the wheel sensor, hope it isn't one as it is pricey. Also going to bleed the system. Checked and the pump is good, TPS as well. Fluid is ok and G Sensor is plugged in.
Originally Posted by JordanS4
(Post 8255474)
Which sensors under the dash area besides the G-Force? I switched to Gravel because it was raining and then coincidentally the water probably shorted out the frayed sensor. Thanks!
For future search references, my problem was caused by a faulty Left Front wheel sensor; the wiring was damaged by rubbing on something.
