Evo thermostat
Hey guys I bought a thermostat from autozone today for my evo and it looks a lot smaller then the one that was in my car, can anyone tell me or show me the correct thermostat
Parts stores usually only stock the lancer tstat which is smaller. You're best bet is to get it from the dealer.
post some pic's
The one from autozon is in fact incorrect. You must go to the dealer. Been down that road. Thermostat was around $40 bucks.
Probably gave you a lancer thermo.
Did they search for the right car? Sounds more like you got a Lancer part. I recommend getting the correct one from mitsubishiparts.net.
I work at Napa, I'm pretty sure we have the right one. check out part # THM 455338
Originally Posted by Bobster22388
(Post 8449576)
ran into the same issue. was at adavance and we looked up for eclipse 3.0, 03 i believe.. and it's just a tad bit taller, but fits fine.. it's also a few degrees cooler.. works great..
Originally Posted by ak47po
(Post 8449585)
Doesn't mean they gave him the right one.
My experience is that if one parts house has an incorret listing, they all do. I think they must work off a universal parts list.
So, anyway, the listing for the Evo thermostat is wrong. I had Advance call the home office to see if I could get them to obtain the correct thermostat. No dice. |
Yah I think i got one for a regular lancer even though I told them it was for an Eco, they tried to tell me it's the same for all of them. Then when I took out the old one you could clearly tell it was definitely not the same
Parts stores fail in getting the right part number, they presume that the Lancer and the EVO ones are the same part number. Lack of research on their part.
Why do people even still go to Advance? The people that work at every single one that I've been to are complete idiots. NO one goes to Napa for whatever reason.
If it runs cooler, wouldnt that be better? I think some companies make aftermarket thermostats that intentionally open earlier, to keep temps farther down.
